How to share map to other users in CRM
3379
06-16-2014 05:30 AM
DaleMichalk
Hi
can you please tell me, How to share Esri map to other users in Dynamics CRM?
DanielLee2
Dale,
Are you using Dynamics CRM 2011 or 2013? The UI is a bit different depending on which version of you are using. For 2011, open the map chart and then on then menu bar, select Charts > Assign. For 2013, open the map chart, then select More Commands (it is the three dots above the chart) > Assign.
