Heat Map Help
2380
09-23-2013 11:57 AM
NathanWright
Within ArcGIS for SP i want to build a heat map from a list that contains lat/long and a column called "Users". I want to break the heat levels into different colors based on the Users column (1-499, 500-99, etc). I cannot figure out how to accomplish this within the SharePint instance, on the desktop version this is a simple task.
KatherineDalton
Hi Nathan,
As you've found, manually setting the heat map intervals is not possible in Esri Maps for SharePoint.
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
