Esri Maps Location colum's type
2888
08-12-2013 04:33 AM
DimaShats
Does anybody success to use column of "Esri Maps Location" type?
Best Regards,
Dima
JohnBojan
Best Regards,
Dima
Yes!
Thanks
KatherineDalton
Hi Dima,
Are you having trouble using the Esri Maps Location column? This column is designed for use with lists that already have coordinate data. The new Esri Maps Web Part will recognize coordinate data even without the Esri Maps Location column, but if you are using the ArcGIS Map Web part (Silverlight web part) you'll need to add it. Check out our help topic here:http://resources.arcgis.com/en/help/sharepoint/concepts/#/Adding_lists_containing_coordinate_data/01...
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
DimaShats
Thank you for your reply.
I use without any problem point location with SharePoint's Lists since previous version of ArcGIS for SharePoint.
I wonder to use not point ESRI Map Location (new type of column added in ArcGIS for SharePoint v3).
Thanks in advance.
