Can't access My Maps in Map Center
1700
05-02-2014 11:10 AM
ShannonMartel1
I have created a web map with ArcGIS Online but I can't see it under My Maps.  Is there something I am missing.  I shared it to my organization.  Do I have to make it public to see it?
Thanks!
KatherineDalton
Hi Shannon,
If you're logging in to the Map Center in SharePoint with the same login you used for ArcGIS Online, then the map should appear even if you have not shared it publically. If you have quite a few maps already you might need to go to the next page of maps as new maps are listed at the end, not the beginning.
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
