Hello,I have a customer in our Business Objects group who is trying to add data using the ESRI Maps for BO. He creates his data from a spreadsheet within BO, selects data, binds the data and so forth...step by step according to the help via ESRI. After "add data to map" and it finds his layer, the define the location option doesn't have a list to select from. The "How is location represented in your data", (specify how locaiton is represented in the current dataset ex:lat/long, address, US City, US State, etc.) list is empty. Any suggestions on what we might be missing?[ATTACH=CONFIG]32333[/ATTACH]Thank You.Allison
While adding any data, i am not getting any list of Location Types. When i checked, i found the below url is not giving any repsonse.
http://server:8080/em4bobj/dashb/proxy.jsp?http://la.arcgis.com/common/locationproviders/LocationProviders.xml
I am getting attached error.
I tried updating proxy.config file, by setting mustMatch = true and adding tag <serverUrl url="http://la.arcgis.com"/>. However, it did not help.
Could you please let me know what is UpStreamProxy and how to use it.
Thanks & Regards,
Vara Prasad.
Finally the issue is resolved by customizing proxy.jsp page to include code for proxy authentication. It might be required because of restricted network in my office.
Hi Shirley
By upstream proxy, are you referring to the proxy server for the organisation?
We have this enabled, restarted Tomcat and still not able to add from the table.
We have ESRI Maps for Business Objects and it is is falling down at the point where an excel data source does not show up in the panel on the left when it is added to the ESRI Control in dashboard.
ArcGIS Server 10,2
Portal 10.2
em4bo v2
Susan
Hello Susan,
The scenario you mentioned is not as a result of a proxy configuration. You will have to bind your excel data to the map. Follow the following steps to do that:
For more information on how to bind data to your map, refer to the build a map enabled dashboard section of the documentation,
Hope this helps.
Shirley
Hi Shirley,
many thanks. You are too awesome.
I'll pass it on to the BO Developer this morning. We will get some testing done and report back shortly, in the next 2-3 hours.
Do we still have to have the proxy configs set up if we are in the same corporate network?
Signed in members can post, follow updates, and more. New here? Register a free account.
