Turn off Enlarge the Visual Message
770
11-15-2024 11:18 AM
ArielLow2146
Hello. I have a Power BI report I've shared publicly using the publish to web method. When I load the visual in an incognito window using the public URL I'm still seeing a message about enlarging the visual to continue editing.
The map is intended to be a reference map and there are no editing capabilities available to the public. Is there a way to turn this message off so it doesn't appear for all users?
NaZhang_Esri
Hi @ArielLow2146,
Thanks for your question! To ensure users have a good experience viewing/editing the map, this message shows up. If the map is too small, it's very hard to see all the information on the map. We will see what we can do with your concern.
NaZhang_Esri
Hi @ArielLow2146,
ArielLow2146
@NaZhang_Esri Thanks! In this case I'm only trying to show the feature selected in a slicer so due to the simplicity of the map it makes sense for it to be small and is confusing to folks to see a message about editing since that's not a capability they have.
It would be great if there was a way for the PBI creator to elect whether or not to show the message.
RodPBI
@nazim Note that ArielLow2146 is "Publishing to the Web".  In my experience the visual doesn't work when published to the web.  Has this changed?
