return information about clicked ArcGIS online polygon into power bi
1191
07-19-2023 03:36 PM
MikeAbecina
Hello everyone,
I'm working with a feature layer in ArcGIS Online, which contains polygons. I have successfully imported this feature layer into Power BI using the ArcGIS for Power BI add-in. However, I'm wondering if there is a way for Power BI to identify the specific polygon that I click on, so that I can apply filters to the data I have loaded into Power BI based on the polygon's ID in ArcGIS Online.
Any help or suggestions would be greatly appreciated. Thank you!
NaZhang_Esri
Hi @MikeAbecina ,
Thanks for your question! Have your tried Join layer?
In addition, you could also Interact with other PBI visuals by checking it on when you select your ArcGIS layers in the selection tool.  https://doc.arcgis.com/en/microsoft-365/latest/power-bi/select-features.htm
Please let me know if you have any further questions. Thanks!
MikeAbecina
Thanks @NaZhang_Esri  for this. I've played around with this feature. It's pretty good. Is there a way to interact with the map without having to hit the link icon (and have the 'join layer' pop up always open)? Also, I have the join being 1-1, but its still quite slow and can crash - do you know of any helpful fixes for this?
