Lat/Long Precision in Tooltips
628
07-27-2022 12:48 PM
DouglasKnabe
While I can live with and see the value in having the lat/long displayed in the tooltips on a map when I hover or select a point, it inappropriately rounds to two decimal places. The field in the table is set to 6, and I have confirmed that it's not just cutting off zeros. If we are forced to display data, it should at least be correct. Is there not a way to adjust this precision?
AnthonyLatini
@DouglasKnabe - Thank you for this topic! We have identified this as a bug and have logged it appropriately in our project. Once we have an update and fix for this, I will post the results here. Thank you for your patience on this issue as we work through it!
