GIS map in Published Power Bi Report only loads in Chrome, not Edge
722
11-19-2024 03:44 PM
PaigeHansen
Has anyone experienced this issue with the ArcGIS map on a published Power Bi report?
Chrome has no issue loading the map, but Edge leaves the map blank. Does anyone know of a way to fix this?
ShaneONeill_144
Is your Edge on the latest version? Does this also happen in Firefox? Do you have a link to the report so I can test?
RodPBI
Hmm, I use Edge exclusively and I have never encountered this issue...  NOTE that the ArcGIS visual ONLY works when the report is shared with licensed Power BI users. It does not work when shared through one of the embedding options such as "publish to the web"
