Drive-time Select option doesn't show up
1288
01-15-2021 07:18 PM
KatherineHuang
Hi there! When I add a drive-time layer to my ARCGis Map in Power BI, for some reason the "drive-time select" option does not always show up.
I have a very simple power BI. The dataset is just a list of street addresses with latitudes and longitudes. With a blank report, I added an "ArcGIS Maps for Power BI" visualisation. I added the latitude and longitude from the dataset. I then created a drive-time layer using the "Analysis tools" list (shown in purple below).
Once that's done though, when I click "Selection tools", the drive-time selection option doesn't show (see screenshot below). It works in one of my older Power BI files, so I can't understand why it's not coming up here?
I'm using Power BI Desktop version 2.88.1144.0 64-bit. Thanks in advance for your help!
P.S. It's my first time on the forum so apologies if I've missed anything!
JonEmch
Hello Katherine!
Excellent question. It appears that you first have to select the drive time layer in the Layer List:
After this, you should be able to see the selection tool pop up:
Please let me know if this helps!
Edit: Added the correct screenshots.
Keep on keeping on!
JonEmch
Hello Katherine!
Keep on keeping on!
