Clustering of points prevents tables from filtering
442
05-09-2024 04:55 PM
Labels (2)
RobTomkies
Hi All,
Currently visualizing a large dataset containing ~5000 points of latitude and longitude locations. These are related to other tables via a semantic model. When I select a row in the table the map visual zooms to the relevant point. When clustering is turned off, I can select a point on the map and the table will filter to that location. However, when I turn clustering on - I can select the table and it will filter to the point, but I can't select a point and have it filter the table. This seems buggy to me but has anyone found a workaround?
Rob
Tags (3)
