Adding data by area and layer points
2523
10-28-2022 04:44 AM
EduardadeOliveira
Hi guys, I'm very new to "esri and PBI world"...
I have a question: if possible, how can I add a second layer of data in points on a map, as I already have the first layer by municipalities area.
Being more clear: I have a map from all cities in brazil segregated by color in a heat map with some data I need to see regarding sales, I would like to add another layer with points where the stores are located.
Can anyone help?
Tags (3)
SarahRosenthal1
Hi @EduardadeOliveira
Currently only one layer from Power BI data can be added to the map.
However, you can also add a reference layer to the map using ArcGIS content.
If you are an ArcGIS user you can upload your store location data to your ArcGIS Online organization, then add that layer to the Power BI visual through the same reference pane by selecting "My Organization" from the dropdown menu.
Hope that helps!
SarahRosenthal1
Hope that helps!
SamRossfemadhsgovRoss
Sarah   I used to have "My organization" but I no longer do.  Do you know if this is a change in esri or if it is something within my organization?
EduardadeOliveira
It does help, thank you!
