Deprecating 2020 Demographics Layers in ArcGIS for Power BI: Planning for the transition
526
05-22-2025 01:42 PM
NaZhang_Esri
Published date: 05/22/2025
We hope you've been finding the demographics layers immensely useful so far! A previous announcement detailed the deprecation of several demographics layers (Demographic Layers Retiring | 2023). While these layers remain accessible for the time being in ArcGIS for Power BI, they are scheduled for automatic removal by the end of 2025. This change is part of a broader effort to streamline data services, improve performance, and transition toward newer, more robust datasets and mapping capabilities.
You are encouraged to begin planning for this change to ensure a smooth transition and continuity in reporting workflows.
What are demographics layers?
If you don’t know what demographics layers are, access the Layers pane and search for them when adding ArcGIS layers. It’s a separate tab named Demographics. These layers are typically added to enrich map visualizations with contextual data.
(ArcGIS for Power BI – Demographics layers)
For more information about demographics layers, see the following:
Why are these layers deprecated?
Esri periodically reviews its data offerings to ensure they remain current, accurate, and aligned with your evolving needs. The decision to deprecate the legacy demographics layers reflects:
  • Data modernization: Many older layers are based on outdated data sources that no longer meet quality or relevancy standards.
  • Performance improvements: Simplifying layer options helps speed up map rendering and improves the overall responsiveness of reports in Power BI.
What do you do now?
These layers will continue to function until their removal date, but we highly recommend not to rely on them for long-term reporting or new projects.
If your reports rely on these demographics layers, here are some steps to prepare:
  1. Identify usage: Audit your Power BI reports for any use of ArcGIS demographics layers.
  2. Transition to supported content: Explore ArcGIS Living Atlas layers, which includes updated demographic and socioeconomic layers that can be added to provide more contextual information for your map and report.
Stay informed
Exciting new demographics layers with more map capabilities are on the way in the upcoming June 2025 release. We will provide more detailed timelines and documentation throughout the deprecation process. We encourage all ArcGIS for Power BI users to begin planning your transition and stay tuned for future updates.
As always, please reach out if you have any questions!
Contributors
