When a record is created in a feature layer gives webhook naming error, webhook name already exists
720
07-19-2024 02:43 PM
Peters_Amy
My Trigger is ArcGIS (yellow) "When a record is created in a feature layer" and it's hosted.
Errors while creating webhook: Webhook name [power-automate-c1a1cb0588d3407297ff94db44adcc70-FeaturesCreated] already exists. Please be sure to use a unique webhook name.
I'm new to MPA.  Thank you for the help!
TimLohnes1
Ever figure it out. I have seen it a couple of times, usually happens when I have multiple flows calling on the same hosted feature layer.
I just had a flow working for 3 or 4 weeks. Then I made a copy of it to test some enhancements. Turned off the original. Now I turned off the new one and turned back on the original and it gives me that error, doesn't work at all.
Please help. This can't be the expected behavior to have my flows break every time I make a copy.
Thanks for any thoughts or tips.
