Issues with opening .DBF extensions in Excel 2016
1971
12-09-2019 05:21 PM
StuartBailey
Issues with opening .DBF extensions in Excel 2016 .
Recently upgraded all machines with Win 10 build 1905 and office 2016 64 bit
now finding that Esri users can no longer open these .dbf files unless they use a work around
by opening excel first then browse for the file using the all files filter.
I had this working by adding the extension and the association in win 7 64 bit and office 2016 with a registry hack.
this no longer works with win 10 / office 2016 64 bit.
why is this extension required for something that is basically a source file for >. shp files
couldn't this requirement be created with a standard extension (XML /XMLS Etc) that is compatible with current OS and Office software?
having to a create the extension then add the association as in the past now only to find this no longer works either.
creates down time for users and hands of a resolvable issue and further workload to IT support.
Tags (1)
DanPatterson_Retired
Table to Table and Table to Geodatabase are the options for bringing into ArcGIS Pr
Then Table to Excel if you need go to excel
Converting the shapefiles to file geodatabase featureclasses would make it easier
An overview of the To Geodatabase toolset—Conversion toolbox | ArcGIS Desktop
Feature Class to Feature Class—Conversion toolbox | ArcGIS Desktop
Table To Geodatabase—Conversion toolbox | ArcGIS Desktop
and
Table To Excel—Conversion toolbox | ArcGIS Desktop
StuartBailey
Hi Dan
Thank you for the reply greatly appreciated , I’ll pass this onto staff and see how we go.
Best regards
Stuart Bailey
Information Systems Manager
Anangu Pitjantjatjara Yankunytjatjara
PMB 227 UMUWA
via Alice Springs NT 0872
Ph:
Mobile: 0488202046
Satelitte Ph: 0147180907
mailto:Infosys@Anangu.com.au
<https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.facebook.com%2FAPY-Lands-Anangu-Pitjantjatjara-Yankunytjatjara-1466117813680902%2F&data=02%7C01%7Cinfosys%40anangu.com.au%7C3d46cb1137694f2a4c2b08d768a4dff0%7Ca1240eb104ae4a888522072b2ca6f466%7C0%7C0%7C637092929674880551&sdata=%2BgfMw8LMWtTOEyt9UX6Z5qj3Vv31%2BotUx2ri1TnB4xs%3D&reserved=0>Follow APY on Facebook
APY Website: www.anangu.com.au<https://aus01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.anangu.com.au%2F&data=02%7C01%7Cinfosys%40anangu.com.au%7C3d46cb1137694f2a4c2b08d768a4dff0%7Ca1240eb104ae4a888522072b2ca6f466%7C0%7C0%7C637092929674890543&sdata=Xd5IhA%2FsiEkBIjKegJCYmI35iyLMJ8xIlif%2Fu8AZMk8%3D&reserved=0>
