Multiple layers within a single spreadsheet
1926
03-07-2025 02:52 PM
Mark_
Within a single spreadsheet, I am attempting to create/add a second layer using data on a second sheet. When I select the cells on the second sheet in the 'Add layer' dialogue, I receive an error saying "Data already belongs to a hosted ArcGIS layer". Is this simply not possible or am I missing something?
To clarify:
Sheet 1 data → layer 1 created; works fine
Sheet 2 data  x  unable to create layer 2
ShannonCardoza
Good afternoon @Mark_
Thank you for posting your inquiry. Another user had reported similar behavior, can you check the workflow in this post https://community.esri.com/t5/arcgis-for-excel-questions/cannot-add-the-worksheet-to-arcgis-for-exce...
For Sheet 2 are you trying to add the same Excel data from Sheet 1? Or are these two entirely different datasets on the sheets?
Thank you!
-SC
Shannon Cardoza
Product Engineer
ShannonCardoza
Thank you!
-SC
Shannon Cardoza
Product Engineer
Mark_
Two different datasets on the sheets.
ShannonCardoza
Thanks @Mark_ the current workaround still applies - copy the data, then paste it to another sheet using "Paste with Values".
Shannon Cardoza
Product Engineer
ShannonCardoza
One more mention  @Mark_ if you delete the shared layer, you will be able to re-add the data again.
Shannon Cardoza
Product Engineer
MarkYoung2721
I have the same error but I have deleted the hosted feature layer on Portal (11.3) so not sure why its still giving me the error Data already belongs to a hosted ArcGIS layer.
Thanks
Mark
