ArcGIS for Excel in GCC HIGH Environment
1156
04-24-2024 12:18 PM
MelRoyer
Does anybody know if ArcGIS for Excel is available with a Microsoft 365 E5 for GCCHigh license?  I have looked high and low on both the Esri and Microsoft sites and boards and can't find a definitive answer.
Thanks!
ShannonCardoza
Good Afternoon @MelRoyer Thank you for reaching out! ArcGIS for Excel is not available with a Microsoft E5 GCC High license.  This would require your IT team to make an exception to go to a .COM CDN to get our static resources.
Hope this helps and apologies on not being able to find a definitive answer.
Best,
SC
Shannon Cardoza
Product Engineer
MelRoyer
Hi Shannon, I appreciate you responding.  Do you know if there's documentation re: setting the exception?
ShannonCardoza
@MelRoyer I found a few resources that may be helpful, see below:
From my understanding, you would be going to File > Options > add-ins > Manage > select COM add-ins from drop-down -
Just keep in mind this workflow will need to be specific to your environment and needs. I would refer to Microsoft help for support for additional guidance.
Shannon Cardoza
Product Engineer
