ArcGIS for Excel Add-In Function Doesn't Work - Says "#busy!"
2536
08-04-2023 09:52 AM
Lindsay_Maier
Hi all,
I have the ArcGIS for Excel Add-In installed, and I'm trying to use the getcoordinates function, but it doesn't seem to work. It just says "#busy!" and never loads (see screenshot). I'm logged in to my account, and I have plenty of credits available. I'm not sure what I'm doing wrong. Any ideas? Thanks in advance!
ShannonCardoza
Good morning @Lindsay_Maier
I double-checked the workflow you mentioned using an address from the screenshot provided and did not have any issues. I will mention, however, sometimes users need to refresh. Refresh using the 'green circle' looking refresh button next to the word #BUSY. This has worked for me as well.
Let me know if this helped!
All the best,
SC
Shannon Cardoza
Product Engineer
Lindsay_Maier
Hi Shannon,
Thanks for the response. Unfortunately, refreshing doesn't do anything. It still just says busy... I'm wondering if there is something wrong with my add-in, though, because when I opened Excel just now (literally just opened a blank worksheet in Excel, went to the ArcGIS tab in the ribbon, and hit "show map", the attached screenshot popped up at the bottom...
ShannonCardoza
@Lindsay_Maier Was the add-in deployed at the admin level? You may want to clear the office cache and try the workflow from the beginning. This resource may be helpful.
Shannon Cardoza
Product Engineer
Lindsay_Maier
Hi Shannon. Yes, it was deployed at the admin level...
ShannonCardoza
 @Lindsay_Maier The error message from the screenshot is typical when 2 app deploys were attempted. This may also be helpful to try:
In Windows, Excel desktop, you can also clear web Add-Ins cache using these steps -
Go to Excel -> File menu-> Options -> Trust Center tab -> Trust Center Settings -> Trusted Add-In Catalog tab -> Select Next time Office starts, clear all previously-started web add-ins cache checkbox -> OK -> Restart the Excel.
Please let me know if this resolves the issue.
Shannon Cardoza
Product Engineer
