How to export from AutoCAD C3D to shapefile
8171
01-21-2016 06:45 AM
JasonBryant
I have a dummy file with a couple of polylines with custom attributes added using the features menu.
I want to export the file to a shapefile and have those attributes be attached as object data.
Any help would be appreciated.
Civil 3D 2014 with ArcGIS 350 plugin.
KyleBalke__GISP
JasonBryant
I can export it using this method, I am just missing the object data I created using the feature class attributes.
KyleBalke__GISP
I think the object data can only be exported separately as a table...you would then need to do a join in ArcMap.
Exporting object data to an external file | AutoCAD Map 3D | Autodesk Knowledge Network
