As you can see I have a point that I brought in using the plugin.
I can find this point using AutoLISP esri_featurelayer_select() command BUT ONLY if I search by objectid (which i dont want to do). See cases below, these are copy/paste from commandline output.
Command: (setq test (esri_featurelayer_select "STREETLIGHTDETAIL_BLOCKS" "" (list (cons "ATTRIBUTEQUERY" "objectid = 223838"))))
(sslength test)
When I try to select by blockname or dwgname, I get 0 return.
Command: (setq test (esri_featurelayer_select "STREETLIGHTDETAIL_BLOCKS" "" (list (cons "ATTRIBUTEQUERY" "blockname = AR.121"))))
(sslength test)
Command: (setq test (esri_featurelayer_select "STREETLIGHTDETAIL_BLOCKS" "" (list (cons "ATTRIBUTEQUERY" "dwgname = Streetlight_Detail_CLEAN.dwg"))))
(sslength test)
Is my query wrong? Am i handling strings wrong? I feel like i've double checked everything...
