Can't find Generate Label user interface
1208
08-20-2024 01:36 AM
MCh
I've upgraded my ArcGIS for AutoCAD plug-in to 430 version, but I can't find this 'Generate Label user interface' function at all.
https://doc.arcgis.com/en/arcgis-for-autocad/latest/manage/generate-label-user-interface.htm
Could someone guide me for this?
Thank you in advance!
MCh
I've already tried that command and the result looks like this.
However, I found out the solutions now.
The first one is do the right click at the feature class and select Labels > Generate then the interface will appear.
And the second one, I just know that there is difference between ESRI_GENERATELABEL command and -ESRI_GENERATELABEL command!
So that's why I can't find the interface I'm looking for.
-ESRI_GENERATELABEL command bring you to the first picture.
ESRI_GENERATELABEL command will get the interface for you.
I'll left this to people who confront this issue like me. 🙂
KarenHodge
There are a couple of ways to launch that interface.   One way is the Esri_GenerateLabel command (https://doc.arcgis.com/en/arcgis-for-autocad/latest/commands-api/esri-generatelabel-esri-generate-la...).  I believe it is also available as a context menu on supported layers in the Table of Contents.
MCh
