arcgis for autocad
897
07-12-2017 06:40 PM
SergioRugik_Gomes
Hi there, when I try to open ArcGis for AutoCAD 365, I get the "No valid version of AutoCAD installed" message. I have checked the install requirements and apparently I have all that I need. Could it possibly be because my Autocad is a Student Version? If not, what can I do?
DanPatterson_Retired
From here https://blogs.esri.com/esri/arcgis/2017/05/25/whats-new-in-arcgis-for-autocad-365/
It only says
ArcGIS for AutoCAD works with 32bit and 64bit  basic-AutoCAD, AutoCAD Civil 3D and AutoCAD Map 3D versions 2013-2017.  Although not certified at this time it may also be used with AutoCAD 2018.
but doesn't mention the student version.
