Terrain Follow and Minimum Height Return in steep terrain
364
04-28-2025 04:37 PM
oregonparksgis
I'm interested in using Flight to run missions using our P4RTK in steep terrain where my takeoff location has to be at the bottom of a canyon and the flight area hundreds of feet higher up hill. I have some questions about the settings in the app.
The Minimum Return Height description in Flight says this setting is for: "Minimum height above takeoff point during return home. Drone will not follow terrain during return home"  So what happens if my project area is 620ft higher than my takeoff point and this setting is at 620ft? Is it goodbye drone?
Similar and perhaps more important question for the Departure Height, which just says this is for "Height while traveling to the first waypoint."
Hope someone can help clear this up.
