Using Coded Domains with ArcGIS Enterprise and Field Maps
1071
12-09-2021 08:28 AM
GregDunnigan
  • I am using ArcGIS Enterprise and ArcGIS Server with a SQL Server database.
  • I have a Service that is symbolized by a Numeric Coded Domain where I have a numeric code and a description
    • 1:Desc1
    • 2:Desc2
    • 3:Desc3
    • etc
  • In Field Maps when looking at legend, all looks well..I see the symbol classes with what I want to see by description (Desc1, Desc2, Desc3 etc)
  • When I edit the feature classe, I see the coded (1,2,3,etc)
  • Due to some constraints of how the data in the SQL Server database gets populated, I can't change the Domain Table...it has to be the Numeric Code
Is there any way via Arcade, or the Field Maps Application, hacking JSON (or any other way) to change  what is presented when creating a new feature, so that the description is displayed, and not the code?
Kanin
by Esri Contributor
Could you try changing the labels of the symbology in the underlying web map from the codes to other values and see if this change is respected in Field Maps?
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
