Using Calculated Values to populate Contingent Values
7632
17
07-22-2023 05:20 AM
OliverIshmael
I have set up a field group with Contingent Values to help filter combo box fields on my form. For some of these fields, I am using Calculated Values to populate default values to save users time.
The contingent values function properly within the form but once the user has filled out all the fields in the field group, Field Maps displays the error: 'Value combination is invalid' and then the survey can't be saved.
Is this a known issue / is there a workaround?
OliverIshmael
(view in My Videos)
KevinBurke
Thank you for the video @OliverIshmael . That is similar to what I configured on my end using my data and it worked fine in my case. So therefore something else must be going on.
Is that map/data hosted in AGOL?
Can you share a copy with me to test with?
-Kevin
OliverIshmael
Hi @KevinBurke do either of these users relate to you:
KevinBurke
Hi @OliverIshmael
Please use the ArcGIS Field Maps user account.
Thank you
-Kevin
OliverIshmael
Thanks Kevin, I have sent you an invite.
KevinBurke
Thank you for sharing the map with me @OliverIshmael . Can you also please share the feature service to the group? The map cannot successfully load for me to see the form without it.
OliverIshmael
Hi @KevinBurke sorry about that, please try again.
KevinBurke
Thank you @OliverIshmael. I've been able to resolve the issue.
For the Region and Site fields, your calculated expression needs to be changed to the following:
- return "1" for the Region field
return "2" for the Site field
The reason for this is because the value above represents the code in the coded-value domain applied to those fields. When the form loads in Field Maps, you will see the correct descriptions of "North West Wales" and "Coed y Brenin Forest Park" applied and the contingent values will work successfully.
In arcade the syntax above assumes the value getting passed is the code and not the description, which is why it wasn't working previously.
-Kevin
