Unsupported Layer Type - Stream Layer
1313
12-08-2023 01:41 PM
JeffSilberberg
Have a Velocity Analtic that is outputting a Stream Layer among other things.   While the Stream Layer is fine, in a Web map, a DashBoard, and an Experience Builder Web page, when it's incorporated into a Field Map the endpoints do not show up but a message does "Unsupported Layer Type".   The workaround appeared to be to rebuild the Stream LAyer with the Options Box checked to "Also publish a feature layer which keeps the latest observation for each Track ID".
So, is this expected behavior?  Is there a Blog Entry or Documentation that talks about this issue?
TIA --
