Unable to sync offline edits
1111
04-10-2026 08:41 AM
Alison_Mynsberge
Using iOS devices and Field Maps 26.1.1, we have been unable to sync edits made offline. The errors are "Invalid JSON: The supplied JSON could not be parsed" which is also the general extent of the information we get from verbose logs.
Verbose logs are generally:
Preparing to sync 1 geodatabase
Sync geodatabase: Failed: "Job error 21 Invalid JSON. The supplied JSON could not be parsed."
Layer result: Sync failed. Name: ..... The supplied JSON could not be parsed.
Table result: Sync failed. ... The supplied JSON could not be parsed.
I wish the verbose logs included the JSON!
Alison_Mynsberge
The goal is to edit a table related to the feature class.  We're able to edit from field maps without any trouble when online.
DougBrowning
MVP Esteemed Contributor
Is this Portal?  We have been seeing this setting here getting turned on by default now in Portal and we have to turn it off.  Not sure why its suddenly doing that.  It caused what you are seeing can edit online but not offline.
Hope that is it
ChristopherCounsell
MVP Frequent Contributor
I believe error code 21 is field type, like the below:
https://support.esri.com/en-us/knowledge-base/error-arcgis-field-maps-domain-com-esri-arcgis-runtime...
Are you using date or time only fields? Or these arcade functions?
Otherwise need more info. Can narrow it down by testing new layers to isolate it to the fields, offline, relationship, map design etc
DanielFox1
@Alison_Mynsberge
I would look at the link above from Christopher it highlights the error perfect and the next steps. If you want to keep the data you have edited I would recommend following this workflow to extract the changes from the device then make any changes outlined in the above doc
https://support.esri.com/en-us/knowledge-base/how-to-access-offline-edits-from-arcgis-field-maps-dir...
