Unable to submit a visit with photo attached in Field Maps app
1035
04-14-2022 04:51 PM
SueeWang
Hi, I am getting an error whenever trying to submit a visit with attached photo. Has anyone encountered the same issue? Error msg is attached.
ChristopherCounsell
MVP Frequent Contributor
Is the map offline? If so, was the feature layer modified? Sync enabled/disabled, fields removed? Layer removed from map?
Do you get the issue if you reload the map on a new, fresh device?
Do you get the error editing in the web browser?
Are there required questions or field configurations that may cause issues?
