Unable to Open Mobile Map Package MMPK in Field Maps 24.1.0 Build 1055
4466
13
03-01-2024 09:11 AM
WillyLynch3
Using ArcGIS Pro 3.2.2, I created a Mobile Map Package (MMPK).  It can be opened in ArcGIS Pro without issue.
However, when shared to a mobile device it fails to open in ArcGIS Field Maps (24.1.0 Build 1055) with message:  “Unable to Open  Required client version (13.2) is higher than ArcGIS Runtime supports (13.0)”
Anyone else have similar issues?  Data sourced mostly from hosted feature services.
WillyLynch3
With the release of ArcGIS Pro 3.4.0 in early November 2024, this issue is resolved.  A MMPK created with ArcGIS Pro 3.4.0 now opens without issue using Field Maps 24.3.0 Build 1133.  I understand this is all now compatible with the newest SDK's released with ArcGIS.  Thanks to Esri for sync'ing up the versions.  Upgrade to make sure all things work for you.
WillyLynch3
Seemed like a strange issue.... so submitted a support ticket to Esri.  Learned this is a bug-- BUG-000164501: When accessing a hosted feature layer with a date field in ArcGIS Pro 3.2, an asterisk was added to the date field name, causing a failure to load the layer in Field Maps for created mobile map packages.
If you use map packages generated with ArcGIS Pro 3.2, be aware.  A fix is under review.
MatthewStull1
Yea, the new data field type in 3.2 is a big reason to be very careful when upgrading to 3.2.  We've held off on that upgrade just for that reason.
BarryReno
Hi, I am having this same issue. Did you end up finding a fix?
MatthewStull1
Did you make sure you were using the most recent version of the Field Maps app?
WillyLynch3
Yes, when originally identified, used ArcGIS Pro 3.2.2  and Field Maps 24.1.0 as "current" versions.  Now using curerent/newest versions of Field Maps 24.1.1 and making the MMPK with ArcGIS Pro 3.3 and still get the same error on attempting to open the MMPK on mobile device--  “Unable to Open  Required client version (13.2) is higher than ArcGIS Runtime supports (13.0)”   Only option is to use an older version of ArcGIS Pro (v3.1.x) to create the MMPK.  Ouch.
TravisSizemore
I am seeing this exact error during sync on Field Maps, with no MMPK attached to the feature service. The data hasn't been edited by Pro with greater than 3.1 to my knowledge. Anyone find any solutions? We can't sync the data.
WillyLynch3
Per your post, Solved: Sync error: "Required client version (13.2) is hig... - Esri Community, I see your issue was resolved with a simple app sign out and sign back in-- good for you.   For me, the MMPK issue remains with the newest JUNE 2024 release of Field Maps- 24.2.0 Build 1067 on iOS.   Solution offered was to not use data with date/time fields (not possible with field collection data) or use ArcGIS Pro 3.1 to generate the ArcGIS Runtime 13.0 compatible MMPK files (not a very viable solution).  Hopefully the Road Map for Field Maps will someday include support for ArcGIS Runtime 13.2 as per current ArcGIS Pro 3.3!  Other suggestions or comments most welcome.
WillyLynch3
Michael_Dawson
Definitely not solved. Just attemped with an exported mmpk from ArcGIS Pro 3.4.2 and opened in Field Maps 24.3.0 Build 1133 on iOS and got the same error.
