Using ArcGIS Pro 3.2.2, I created a Mobile Map Package (MMPK). It can be opened in ArcGIS Pro without issue.
However, when shared to a mobile device it fails to open in ArcGIS Field Maps (24.1.0 Build 1055) with message: “Unable to Open Required client version (13.2) is higher than ArcGIS Runtime supports (13.0)”
Anyone else have similar issues? Data sourced mostly from hosted feature services.
