Unable to open MMPK (created in ArcGIS Pro 3.5.1) in Field Maps (25.1.0 build 1529)
1086
06-18-2025 09:01 AM
MichaelRowley
I am trying to send a map from ArcGIS over to Field Maps with MMPK. I used the "Create Mobile Map Package" tool to compress my map to a single file, then I used the "Share Package" tool to send it to ArcGIS Online, which I have linked to Field Maps. The map appears with a thumbnail under "My maps", I tap download, it then shows under "On device", but when I try to open it, I get the following error messages: "Unable to open" above "Item type not supported in Geopackage". The .mmpk files I've created mostly range from 3.1-3.3 mb in size.
Things I have tried:
  • Side-loading the .mmpk file directly onto my phone. This allows it to appear under "On device" like the online process, but with no thumbnail, and it returns the same error message when I try opening.
  • Using the "Package Maps" tool instead of "Create Mobile Map Package", creating an MPKX instead of MPPK. Does not appear on Field Maps via the online route.
  • Reinstalling Field Maps, signing out and back in
  • Creating MMPK files with changes to the map, including:
    • Just basemap
    • Just a single point layer
    • No layers
    • Removing all high precision fields (date/time with *; mentioned as problematic in some discussions)
    • Checking/unchecking "Enable Anonymous Use" and "Reference online content"; Adding/removing titles/summaries
    • Limiting to a smaller extent (.mmpk file size is 2.6 mb)
I don't have any more detailed information about the error message, and I'm not sure how to attach a screenshot to this post. I've tried my best to exclusively follow ESRI documentation to get an offline map to appear on Field Maps, but it seems like I've hit a wall here and I don't know what else to try.
Thanks for any advice or insight anyone can provide!
Michael
MichaelRowley
Thank you for your response, Kerri! I tried this tool (which was more streamlined than the way I was attempting) and Field Maps was able to render some of the layers, but not all of them. All of my layers were saved as Feature Classes in ArcGIS, but I was eventually able to get all the layers to load in Field Maps by converting them to Shapefiles using the "Feature Class to Shapefile" Geoprocessing Tool. Once my layers were all Shapefiles, I followed your steps and it worked flawlessly.
KerriRasmussen
Hi @MichaelRowley . When you create your MMPK, there is an option to share it to your ArcGIS Online Organization, you shouldn't need to use another tool to publish it to your org. In Pro, select "Share" at the top of the screen > Mobile Map (in the Packages section of the Ribbon) and then when the tool pops up make sure to select the option to Upload package to online account. When the tool is done running, you should see the MMPK in your org and be able to open it in ArcGIS Field Maps. This should work for you. Let me know if  you have any other questions.
MichaelRowley
