Unable to edit editable layer
1218
04-09-2024 11:19 AM
JulianMcCoy
Editing is enabled. One of my colleagues is able to edit the layer. I am not. I am the owner of the editable layer. Attached are screenshots showing the settings of the hosted feature layer in the map (it is the only layer in this web map) and the settings of the web map itself. All maps and layers have been saved and reloaded multiple times in an attempt to get it to work. My organization uses field maps and editable layers all the time and I have not had this happen before. My phone is Android.
DanielFox1
Hi @JulianMcCoy
Are you able to edit the layer in a map viewer rather than the Field Maps App?
Can you turn on the "Keep Track of changes" option in the settings of the layer, does this make a difference?
