Toggle basemap on/off in Field Maps app?
1425
01-26-2024 07:24 AM
SarahKendell
Is it possible to toggle a basemap on and off in the Field Maps app? My thought is that turning off the basemap would reduce battery consumption on the collection device.
ChristopherCounsell
MVP Frequent Contributor
No, this is not possible. I also don't think the basemap impacts battery consumption much.
In my experience these things will use the battery fastest:
  • General device settings - always on display, music identification, apps running in background
  • Device communication settings (bluetooth, wifi and phone network)
  • Device communications - attempts to sync and upload/download data, GPS / location services
What you can do to reduce these is:
  • Put on flight mode if working offline in areas of low connectivity, as more battery will be used to find weaker connections
  • Apply general battery optimization to the device - turn off always on display, bluetooth, music identification, run device battery optimization tools, lower screen brightness
  • Configure field maps to be more optimal with its battery and gps settings e.g.
  • Close apps not in use
  • Turn the screen off when not in use
A chatty location services application with the screen on is a big battery drainer. The above will help mitigate it, but realistically you'll want to be on a newer device with a good/fresh battery, apply general battery optimization practices, and probably keep a spare battery or vehicle charger at hand.
ChristopherCounsell
SarahKendell
Thank you for the information! All things I'll have to implement internally and share with our partners. We do a lot of data collection on iPads that are aging. It probably wouldn't hurt to upgrade those devices.
