Sketch Layers in Field Maps
973
11-06-2023 08:17 AM
LouiseHarris1
Hi
I was wondering if sketch layers are compatible with Field Maps? Firstly I read they are automatically enabled for offline use but noticed when adding a sketch layer to my map it disabled the enable offline setting for the map. Secondly it doesn't seem like you can edit the sketch layers in Field Maps - nothing happens when I select the sketch layer. It would be useful if you could edit sketch layers in Field Maps as they seem a better option than mark up.
Tags (1)
