Searching layer by unique ID on Field Maps
2457
04-22-2022 12:13 PM
DaveBodak
(I also posted this in collector on accident, I apologize if you see it twice)
Hello,
I am looking for search for specific assets in the maps using the unique ID (1,2,3...) previously assigned to each of them. I was able to configure the map for search using the following link:
Configure feature and table search for maps—ArcGIS Online Help | Documentation
The issue comes when trying to search for the asset within the mobile app, I cannot figure out how to search by the ID. I can search for an address without any issues, but there is no place to search for the ID that I can see.
Thanks!
Tags (3)
by Anonymous User
Not applicable
Are you tapping the return/done button after entering the search term? Field Maps supports search suggestions for addresses but not for searching features in layers. So as you type, address matches will appear but you need to take the extra step of tapping enter/done to trigger the layer search.
by Anonymous User
Not applicable
DaveBodak
Yes, that solved the issue, thank you!
