Search for multiple field values in Field Maps
1404
03-07-2023 05:50 AM
kapalczynski
Can I find a record in the Field Map Mobile App that has values in 2 Fields?
Example Attributes of Layer:
Prefix Number         Number            Field1          Field2        Field3
    123             4545454545          value1          value1        value1
I want to search for 1234545454545 and return the record above from Field Maps Mobile Application.
Can this be done... I see where in the Web Map Settings where I can set the fields that can be found in addition to the geocoder....
BUT I cannot see how to search for multiple fields at the SAME TIME.  It only searches one field... I can add additional fields to search on but not at the same time in a concatenated form
I ALSO do not see the ability to find a record based on an Expression that concatenates two fields. In my web map I created an expression to display PrefixNumber and Number in the popup.... I assume I cannot find on the expression?
kapalczynski
I went back into the data and concatenated the two fields into one... simple is better...
DougBrowning
MVP Esteemed Contributor
If you checked out the new layer filtering?  This may work for you.
kapalczynski
