scope of variables
226
07-13-2025 11:56 AM
TracyLove
  1. Is there any possible way to store a variable such that it can be used during the creation of successive features? For example a survey team ID or a reservoir level for bathymetric temperature readings.  So the scope of operation is really the field map when it is opened.
  2. Is there any way to store a variable that can be accessed by any of the arcade expressions associated with a form? So the scope is just within each new features data entry form. For example in my case, multiple fields need to access attributes in the previous record..
var lastRecord = FIRST(ORDERBY($layer,'created_time DESC'));
seems like my field map would run a lot faster if i was not running that query for each field.
