Given all the problems being reported with FM 25.2.x, is there any way to revert to the previous (working) version on mobile devices while the problems with the new version are being fixed?
Dan Gruber
Hey @DanGruber
On iOS this is really only possible if you have a MDM (Mobile Device Management) system setup to push out and deploy new versions of apps onto phones, Apple is pretty strict that only the most recent versions are first. The MDM system may have a previous version stored, that's what our company did for the time being!
If you're using Android, you may be able to pull a previous APK off of an non-updated device and be able to deploy it that way!
Cody
Hey @DanGruber
Cody
