Request: Make Field Maps compatible with GNSS receivers with tilt compensation
848
11-15-2024 09:50 AM
KyleMcCormick
In our experience GNSS receivers with tilt compensation more than double the efficiency of data collection.
Many (most?) of the more recent ones include tilt compensation, from the Trimble R780 and R12i receivers, the Hemisphere S631, the Emlid Reach RS3, all the way down to the $1300 SparkFun RTK Torch.
Currently we are using Microsurvey FieldGenius Android for data collection but some departments here at the City would like to use Field Maps. The only thing stopping us is the lack of tilt compensation compatibility.
Please bring this enhancement into active status.
I am sure many others would concur. If you do, add a request to the thread below.
Debert
Hi Kyle,
Curious what exactly you are referring to here, as I'm in the process of configuring Trimble receivers to Field Maps? I have successfully paired a few DA2s and next will be pairing a few R12i's.
Are you saying Field Maps doesn't recognize the tilt compensation (meaning the R12i needs to be level before storing points)?
If this is indeed what you are referring to, I would agree this is a valid enhancement request.
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
KyleMcCormick
Hi Debert.
My understanding is that field Maps will not recognize the tilt compensation of the R12i.
What is interesting is that the free app SW Maps does handle the tilt compensation of the Sparkfun RTK Torch.
Regards,
Kyle
Jacbrod
Hello,
It appears that many receivers now have tilt option as standard, such as the Leica Zeno.
Will ESRI integrate the transfer of these measurements into ESRI Fields Map, or should we consider other data capture applications ?
Regards
Debert
There are many receivers incorporating the tilt compensation- yes.
However, I think this is more of an Esri Field Maps issue as the Trimble R12i has tilt-compensation but Field Maps only recognizes the tilt-compensation on an Android device (not iOS).
Android is more prominent in other counties, so I believe the idea is to roll out those integrations first- but I could be wrong.
