Questions not showing in correct order on Feature Layer when built in Field Maps Designer
256
02-13-2025 06:09 AM
LauraBoagey1
Does anyone know how to fix the field order on the feature layer when you've built the fields in Field Maps Designer
I've numbered them 1 to 16 and added them in order, but when you look on the Data > Fields tab in ArcGISonline and if you export them to excel, the questions are all mixed up in no obvious order
It's very frustrating
It's not an issue if you build the fields in ArcGISonline. They appear in the correct order, but it's not as easy to build the form there as it is in Field Maps Designer
