Question about ArcGIS Field Maps location sharing
647
05-09-2024 10:52 AM
agoladmin1
Is there a way to configure mobile worker licenses so that a select group of admin users would be able to toggle on/off location sharing for other users?  Please email me with any advice!
Michael McGahee | Sr. GIS Systems Analyst
mmcgahee@septa.org
Service Planning Department
Southeastern Pennsylvania Transportation Authority
1234 Market Street, 9th Floor
Philadelphia, PA 19107-3780
Office: (215) 580-8146 |Cell: (757) 635-8044
KerriRasmussen
Hi Michael,
Good afternoon. It is not possible to toggle on/off location sharing for another user (even if you are an admin). If you need users to use location sharing, you can set the map to require location sharing so that the user would need to share their location before they could view/edit the map. And when they enable location sharing there are duration option that would automatically turn off location sharing after 4, 8, or 12 hours or when manually turned off. I hope this helps.
