Passing values from Field Maps to Survey 123 Form if using Offline Maps
679
01-31-2024 05:13 AM
ChristineTombleson1
Can you populate a Survey123 Form (integrated with Field Maps using a link in a popup on the Field Maps Layer) with field values from Field Maps layer if you are using offline maps in Field Maps?
Thank you!
DougBrowning
MVP Esteemed Contributor
Yes it works offline.
