Packing Offline Areas using layers from SDE and Stand-Alone Server
1542
02-17-2022 09:20 AM
by Anonymous User
Not applicable
Hi All,
I am having an issue packaging offline areas for Field Maps through AGOL in my web browser. My map is made up of 5 layers. There are 3 feature layers that are added to AGOL through our departments stand-alone server and are held in an SDE. The other 2 layers are hosted in AGOL, one is a hosted feature layer and the other is a hosted vector tile layer. All the layers are set up for offline use and show as much when editing Field Maps.
I would like to divide my map into 4 offline areas that can be downloaded by folks in the Field Maps app on their phone. The issue is that every time I package an offline area it fails. I've adjusted the level of detail, the offline area size, and took each layer out to diagnose if that was the issue. No matter what size, level of detail, or layer is in the map the offline area packaging will fail.
Interestingly enough, you are able to download an offline area for this map when using the Field Maps app. Does anyone have any insight on why packaging an offline map would fail through AGOL and the web browser but not in the Field Maps app on a phone? Thank you!
-Jim
2 Solutions
by Anonymous User
Not applicable
Are your feature layers from your server secured?
Assuming they are secured, when you add the layers to AGOL, are you embedding credentials?
by Anonymous User
Not applicable
It turned out that one of my layers was not secured. I removed that layer (which I thought I had done but apparently not) and packaged the offline area. I then secured it within our server and re-added it to AGOL with stored credentials. Packaging offline areas now works without any issues.
Do you know if AGOL does not like packaging layers that are not secured? That seems to be the answer in my case.
Linde_Carmack
Do you know what version of ArcGIS Server you are on? From this articleTo create an offline map area for a web map that contains a secure public feature service, the service must be from an ArcGIS Server 10.8 or later site.
I've had the same issue you're describing - I could create an offline area through the mobile Field Maps app but not package a map area in the browser app for the same map. The server version ended up being the culprit. If it was anything related to standard offline permissions I would think it would fail in both environments for you.
by Anonymous User
Not applicable
Yeah, our server is 10.9.1. Oddly enough we are having the same issue if we use our Enterprise as well.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
There is one layer that is secured. It does have stored credentials. Is there something there that I should look at?
by Anonymous User
Not applicable
