Offline map does not match online map after sync
1104
07-26-2023 03:48 PM
grace_tkow
I have a fieldmap with point data on it - it is filtered to only show points where the deployed field = Yes. We are constantly removing and adding points, these are symbolising our traps. We also work remotely, so use offline maps frequently. When I add more points to the map they show on the offline maps after syncing. However, when I remove points from the map by setting the deployed field = No and they immediatley dissapear from the online map. But, even after syncing, these points remain on the offline maps across the team. This is causing the team to have to constantly download new offline maps so they are aware of where all of the points are in the field.
Does anyone know why this might be occurring?
Cheers
grace_tkow
