No Title After Search features
6374
14
01-04-2021 12:18 PM
vijaybadugu
I configured the Search Functionality in Web Map using "Find Location" and added Query layers. And When I search in ArcGIS Field Maps I am getting results as "No Title" Records. The layer Configured with Display Field and Configured proper title for Pop up using "Configure Pop up " in Web Map. Please find Attachment for more Info
AlixPower
Esri Alum
Hi vijaybadugu,
Sorry you are having this issue. I think this issue would be best resolved if I could see the map, would you be able to share you map with the user arcgisfieldmaps?
Thank you,
Alix
Map2021
I agree I am seeing this same error. I configure inside of the Settings in the Web Map to search my layer. However after you type in your search in Field Maps app, it gives a result entitled "No Title" no matter what you type. Why isn't it showing the actual attribute that is being searched?
BClaridge
I'm having an issue somewhat similiar.  Once in FM and I'm adding features- why are they all saying 'No Title'?  Is there a configure pop-ups etc. I can set to have this name be one of the fields user has entered?
JCrandall
I was having the same issue.  I checked everything and finally found  that I needed  to update the Title in the AGOL map (not Field Maps) under the Tables, not Layers.  In the left pane I selected Tables, Popups, and updated the Title in that location.
vijaybadugu
Hi alix , please republish the service and re-configure the pop up with title . It should be working
Map2021
I am not alix but republishing does nothing to solve this. Merely keeps showing the same problem.
rge_esri
The layer's pop-up title can be configured in ArcGIS Online map viewer using "Configure pop-ups".
If not configured, the default is going to be "No Title".
BClaridge
I'm having an issue somewhat similar.  Once in FM and I'm adding features- why are they all saying 'No Title'?  Is there a configure pop-ups etc. I can set to have this name be one of the fields user has entered?
rge_esri
Yes. The popup title can be configured in ArcGIS Online map viewer using "Configure pop-ups".
