Layers not displaying in Field Maps when filtered by date - no error message
4975
12
05-07-2021 09:37 AM
ErinCourtney
We are experiencing issues with layers not drawing in Field Maps when they are filtered by date using 'not in the last' or 'is blank'. The map was built in Map Viewer Classic, and the layers display properly there and in Collector. Our field users are on iPads with Field Maps. When I open the map in Map Viewer (new), it says it has 'Problem displaying filter'. I tried to rebuild the map in the new map viewer and it makes me resave the filter each time I click on a layer. Even then, using the date filter 'not in the last' or 'is blank' means the layers won't display on the tablet. We have a number of maps that use 'in the last' filter that appear to be displaying properly. No error message is thrown saying the layer didn't draw properly. We have confirmed that it is not just one map showing this issue.
Desktop:
Field Maps on iPad:
ColinLawrence
A fix for relative date filters has gone into the latest runtime (200) update. Unfortunately, the current generation of Field Maps is still on runtime 100.x. Field Maps will incorporate this new version of runtime within the next few major releases (hopefully early 2025) and this will address the problems using relative date filtering. I hope this update helps.
Regards,
Colin
ChrisCyphers
Unless there's a fix I'm not aware of, this bug still exists as of September 2025
ColinLawrence
Hi @ChrisCyphers , the update to runtime 200 for Field Maps will be shipping with in the next couple of weeks. Can you try again when you get the store update to version Field Maps 25.2? Please let me know if you still see issues with date filters at that point.
Regards,
Colin
