Layer not loading in Field Maps: Invalid Token
1737
07-10-2024 06:56 AM
MikhaylaB
I have two layers that won't load in field maps, although they will in Portal. They are shared with groups, and I am in the groups. The error code is 22 and says Invalid Token and Domain: ARCGIS_RUNTIME.
Anyone know what this error is caused by? It isn't all layers, only select few.
DanielFox1
Hi @MikhaylaB
Sorry to hear you are experiencing this issue. I have not seen this error before but I would recommend reaching out to your local distributor for further investigation.
If the two layers are isolated on their own in their own web map do you get the same error?
Are they referenced from ArcGIS Enterprise?
Do you see this error when you are using an offline or online workflow?
CristianV
Hi MikhalylaB,
I'm experiencing the same problem; could you resolve this issue?
MikhaylaB
Hello, I'm sorry to say I can't remember what exactly resolved the issue. Based on the time I posted and what I was working on then, I believe I recreated the data in a new database, re-made my relationship classes, published a new service, and my issues went away. My service was ultimately corrupted and other things weren't working with it either, like my old relationship classes weren't set up how ESRI now suggests.
