Layer filters not picking up new values added to domain
283
04-04-2025 01:03 AM
GarethBaker1
In Field Maps Designer in ArcGIS Enterprise 11.3 I successfully set up a layer filter with the five values in the domain visible. The users have asked for another two values to be added to the domain which I've done in the main layer and have also refreshed the view that is being used in my map.
When opening the map in Field Maps on the phone it only shows the original five values in the list of available filters.
I've tried turning off the filters completely and reconfiguring them but no luck. Have also tried poking around in the JSON within the AGO Assistant in case there was an obvious hack I could do in there but didn't seem to be anything relating to the layer filters.
I will probably raise as a support ticket but just thought I'd check if anyone else has experienced this and has a quick workaround.
Gareth
