Layer failing to load: error code 10018
2309
12-08-2023 08:20 AM
WestFourWishing
Hello all,
I am newer to the back-end side of these issues and really could use some help.
I am having some issues loading a specific layer in Field Maps. I have no issue with the layer loading in any of the ArcGIS Online formats, however the specific layer will not load in Field Maps. All of the other assets that belong to this hosted feature layer, all load with no issue.
I've tried reloading layer and confirming the layer was not set to be hidden. Any ideas or points in the right direction would be greatly appreciated!
The full error reads as: Domain:com.esri.arcgis.runtime.error
Code: 10018
Decsription: Invalid cast.
-Troy
WestFourWishing
Error code resolved. There was a max value for one of the fields that was exceeded.
PierreloupDucroix
MVP Regular Contributor
I have the same error, can you please elaborate on how you solved this ?
CEO of MAGIS
