Layer failed to load
1093
10-25-2023 03:19 AM
SalwaCollas
@FieldMapper
Layers in my map are not loading on Field Maps. There is a red triangle and it says "Layer failed to load". The error, when I share it, says:
"Domain: com.esri.arcgis.runtime.error
Code: 3017
Description: Geodatabase field not found.
The layers were published as Feature layer from ArcGIS Pro 3.1.0, all the rest of the layers are working fine, only this one failed to load.
Can someone help me in this please?
Thanks, Salwa Collas
